Extended Brake Line For K20 ?????
Rolled
Anchorage, Alaska
I am getting ready to replace my brake system in my 82 K20. It is a daily driver so no lift but I may give it a small lift down the road.
Since I may get a lift on it someday, I want to go ahead now and get longer lines. makes sense, right :) 2" to 4" lift would be the possibilities...
What off the shelf part numbers do you know of? Or what other applications have a brake line that will work but are longer than the k20?
My K20 is the 8600 GVW version so the braking is suppose to be different. The rears are 13 X 2.5 and I think the fronts may have a different calliper. Don't know for sure but it may make a difference.
just contact shane74 - he's got a great product and can make whatever you need regarding brake lines. :) check here for his info. i have a set of his lines and couldn't be happier.
