Extended Brake Lines
daleearnhardt01
Richmond, VA
Okay need to clarify a few things....Looking at this stuff:
Extended brake hoses that are 25 7/8" long will fit 10bolt from 89-2000 2wd chevy/gmc from right front but will work for both sides and can be modified to fit a D44.
Part #'s:
Napa - 38872
Raybestos - 38872
Auto Specialty - HB-86045
Coni-Seal - BH-177767
Carquest - SP8820
Rear extended brake hose Napa part #4138068
These will work on a Dana 60 correct? Is the 25 7/8" long enough for a 6" lift? Anybody know autozone part numbers or do I just go get 2 right front brake line for a say 95 2wd truck? What is the rear hose from, will it fit a 14FF, and is it long enough? /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
Edit: Looking on Napas site that part number for the rear doesnt match up to anything. Any ideas? /forums/images/graemlins/peace.gif
The carquest numbers are SP 8820 and SP 8821 for right and left. They can be crossed over to red box (the cheaper) brake hoeses as well. The red box hoses will start with SBH, followed by four digits. Sorry I don't have the part number handy.
Application is an 1988 Chevy C1500 pickup.
As for the rear, I used steel to extend mine so I guess I can't tell you what to use.
Those lines will be long enough for a 6" lift if you run stiff springs and don't flex much. I'm going to have to figure out something for mine to get longer ones, as they were at least 4" too short for me at full droop. Local shops cannot make brake hoses because they cannot buy the banjo fittings. For now I've extended them with an 8" long piece of steel on each side, but I do intend on fixing this by either having a shop make some longer hoses or going with the steel braided ones eventually.
Cool i was wondering this same thing im still in the process of lifting my truck and haven't got to the brakes quite yet. Thanks for the info
The rear is the part number for a napa truestop brakeline and it fit just fine on the back of my brohers burb, but it only has a sf 14b rear, it also would have fit my blazers 10 bolt rear. I am almost 100 percent sure that it will fit yours being that I have never heard anybody complain during their 14bff swaps that their old brakeline didn't mount up. /forums/images/graemlins/waytogo.gif
