Just wondering if you guys know where I can get some longer parking brake cables. I am just about to start swapping the 63" rear springs in and I am deffinately going run into problems with the stock length ones.
Also for those of you who have done this swap before, what length shackles and how much lift did you get? And did you shim the rear? Im estimating that I am going to be around 7 degrees out? ....
