extened brake lines(new question)
85mudblazin
Austin,TX
Extended brake hoses that are 25 7/8" long will fit 10bolt from 89-2000 2wd chevy/gmc from right front but will work for both sides and can be modified to fit a D44.
Part #'s:
Napa - 38872
Raybestos - 38872
Auto Specialty - HB-86045
Coni-Seal - BH-177767
Carquest - SP8820
I found this in a older post and I was wondering, do you buy 2 right side brake lines or both the left and right side, I am a little confused /forums/images/graemlins/screwy.gif
Thanks
-Chris
[ QUOTE ]
You buy 2 of the #38872 lines. It doesn't matter right to left.
Harley
[/ QUOTE ]
How long are these? Can you put more than 2 of them together to get a longer line? I need a line that is 35-40" long for a D60 and can't find any... would this work?
Thanks
POOH
Yeah, I have the same question as PoohBair.
I used the double brake lines listed above from Napa on my d44 front, but now have a D60 and need longer lines.
Dean
[ QUOTE ]
Car Quest has them for $35 a piece. I might as well by the stainless braided ones for $80.
[/ QUOTE ]
People have had problems with braided lines. That's why we're looking for longer rubber ones.
[ QUOTE ]
[/ QUOTE ]
Yikes. I purchased two P/N 38872's from Napa for $34 total.
I finally did the brake line & longer shock install this past week. On my old truck it was less than a direct bolt on because the frame mounting holes are different. But, drilling out the caliper end for the 7/16" banjo bolt was easy. The #38872 lines are about 5" longer than stock and so far work great. /forums/images/graemlins/waytogo.gif
FYI....the OEM application for the #38872 is a '94 C3500.
