Paul Brown
Newbie
I have a 1991 K5 and want to run an external fuel pump on the frame rail instead of the in-the-tank fuel pump. A few questions:
1) Can I modify the 91 tank with a longer pick-up tube (since no fuel pump will be in the tank) and use this tank? Issues with sender etc.?
or
2) Has anyone found an aftermarket tank/fuel cell that will mount in the same position as the stock tank and have the return line capability and purge line? Seems like the roll over vents on some tanks I have used in the past would work for the purge or just eliminate the purge all together.
or
3) Has anyone mounted a fuel cell in the rear of the passanger compartment and plumbed to the external fill point?
I have reviewed the previous posts but they seem to lack specifics. Thanks for any help!!
or
or
