Ez-Wiring 21 and elec fuel pump
RootBreaker
3/4 ton status
Williamstown, NJ USA
Ok so my truck has been rewired for a few years now. Love it. Ez-Wiring 21 kit is nice. It has an elec fuel pump circuit. I dont think it is controlled from a relay.
New tank is here and so is fuel regulator. Would you just move that fuel pump power line from frame over to where tank is and be done or would you add a relay to the circuit?
I figure that its been working how it is with a pace pump but now will be an in tank pump
20160520_101253 by Jeffrey Riggs, on Flickr
I have the same wiring harness and I wired my fuel pump up to a relay. Although my ecm triggers the relay to run the pump. The wiring and fuse is big enough to directly power a fuel pump but it should still be wired with a switch so it doesn't continuously run when the key is on and engine not running.
