sope
I'm planning on buying steel tomorrow to start my pick up slider build this week end. These are going to be bolt on to my half ton frame. I plan on using 5" by about 5" 3/16 plate bolted to the frame. it will be 3 by 3 box tube welded to this plate. I'm a little concerned about the frame cracking at the bolt holes. This is my prefered way to do it. I could weld them on to the frame but I want them to be removable. Comments? Does it seem like a bad design?
