goathearder
I have been wanting a set of rock sliders for a while on my 73 but as all of us 73-75 people know, we don't have access to the same body stiffining ribs as the later guys so the dpi sliders and such won't work for us.
Also, welding to the frame seems to be a bad idea since the body is so much wider than the frame and it would be a huge torque arm.
The most popular option seems to be to just hack the rockers out and weld some steel in place there instead and I really didn't want to do that cause there are no issues with my sheetmetal.
What I decided is to use the method the XJ Cherokee people have been using forever to bolt to the pinch seam. Basically, have a 1.5 x 1.5 piece of steel bolted to the back of the pinch seam and the top of that sits flush with the bottom of the body so it should be pretty effective at distributing the load from any sort of impact. The slider itself is 2x2x3/16 and welded to the 1.5x1.5 support. There will also be additional supports at the front and the back of the slider I just haven't gotten those done yet.
Here are a few pics of what I have so far. I'll post more pics when I get it all finished.
We all buy stuff if we don't have the tools YET to do it ourselves, and there's nothing wrong with that. Or if the cost is so afordable it's just not worth yout time to build it yourself, unless you just want the gratification of doing it yourself. I'm guilty of that, but IF I CAN build it, I usually do.
