Lotsa_Faith
What do you guys think? I still gotta do some grinding, then its off to get powdercoated!!
Good start but still needs a ton of reinforcement before it can be called a roll bar.
All it will need to be able to support is two people sitting and standing up there with a couple guns and a cooler full of beer
Looking at your posts again, it looks like you plan to run the hardtop underneath this rack. You can probably live with the temporary seal leaks around your flat plate, but do you really want permanent leaks after those plates bend up the bed-rails? Isn't there still a way to spread the load out?
right.
