Fabrication “stand off” source
nvrenuf
Holy crap, it's running!
Mobile, Al.
Does anyone make a smaller version of a bracket like this? Maybe ~2” tall?
I’m wanting to mount a 12”x18” flat plastic panel to the interior vertical firewall (aux fuse block / relay panel).
How about a stake pocket for a flat bed or trailer ?.
..might be a bit overkill,but..:thinking:stake pocket for flatbed.jpg
I've used those perforated metal mending plates used in house framing to make brackets for CB radios and other things too..
What dimensions do you need?
Something around 2” tall, the width doesn’t matter.
I would rather not have hardware going through the firewall so my thought was to weld something like this to the inside of the firewall and then screw the panel to the “peak”.
If you have time I’ll take them! If you’re bending a bigger piece, I can cut them apart to save you some work.
Thanks for making them! Let me know how much and I’ll pay you asap.
@ktmoutfront I got the brackets today and they are PERFECT! You should consider working with metal for a living. :D
THANKS again!!
