Hello,
My 1985 GMC K1500 Sierra Classic came with a clock in the lower left hand corner of the dash. Anybody know where I can get it replaced and/or repaired. It started with intermittent operation and now only works if I tap on it. Even then it stops sometime later. I'd like to keep it stock if I can. LMC truck does not list one.
thanks in advance...
If it works at all, you can probably fix it. Odds are its just gummed up. You could pull it out and take it to someplace that works on watches.
Or just wash it well with denatured alcohol, being careful not to wash off the face paint.
Then some really light oil applied sparingly to all bearings and the tube the hands ride on should do it.
Thats if it says Quartz like the one in the picture.
If its one of the older ones, there is one more thing to check.
The older ones were windup clocks. They had a set of contacts hooked to the mainspring that powered a solenoid.
When the contacts touched, the solenoid fired pulling them apart and winding the spring about a 1/4 turn.
As the balance wheel allowed the main spring to unwind, eventually the contacts touched again and it all started over again.
If you have one of those, the contacts may be dirty.
I found out how those worked when the balance wheel fell off one in my mother's car as I was driving it through town.
The mainspring unwound as fast as friction of the bearings would let it.
The second hand was invisible, the minute hand was a blur, and the hour hand was running about 30 rpm.
All this accompanied by the machine gun sound of that solenoid hammering away behind the dash.
Scared the Cr*p out of me. I expected to see the sun going down fast. Thought I had driven into some kind of time warp.
