Factory cruise delete
Mastiff
Tucson, AZ
I long ago got rid of my factory cruise, at least from under the hood. I have two harness things still coming through the firewall, just cable tied off somewhere. One is a big vacuum hose taped to a connector/wires with 5-6 conductors. Then a small blade connector with, I think, four connectors. Inside the cab these go right up high under the dash where it's nearly impossible to see anything.
I was wondering if anyone knew where these things lead, especially the big vacuum hose one. Is there someplace up there I can disconnect this stuff, or remove a box or something? Basically, I'd like to clean up the unused stuff.
the vacuum hose goes to a switch on a bracket in front of the brake beside the brake light switch. the rest of the harness goes up to mount on the passenger side of the brake assembly. i think it is held on with a couple of sheet metal screws.
