where the oil cooler mounts to the block is leaking. im goin to try to do the gaskets on it and wanted to know if anybody else has done it? the gasket set has 2 big o'rings 2 gaskets 2 medium o'rings and 1 small oring. i never done this and do i use rtv silicone gasket maker on any of these gaskets?
good point. ive called a couple shops and one guy said there more trouble then there worth.? said they can throw off oilpressure gauge and catch engine sludge......and when i did the valve cover there was a lot of sludge under the rockers......so i mite just remove it... what do you guys think?
