Factory oil cooler - mount bolt sizes & gasket?
I picked up an OEM cooler from another CK5'er -
http://coloradok5.com/forums/showthread.php?t=255572
I need the mounting bolts, though. Can anyone tell me the P/N for the mounting bolts or their sizes/length/thread pitch? I also understand the adapter uses perhaps a o-ring/gasket combo - any info on the correct part for that?
thanks for any help.
The bolts for mounting the adapter to the block are 5/16"-18 and IIRC 3 1/2" long. Yes there is a gasket and O-ring and your local parts store sells a seal/gasket kit for that.
Thanks!
Additional information for future searchers -
1. Gasket kit - GM P/N 88893990
2. Mounting bolt - GM P/N 09421634 (you will need two)
