handloader90
Building!
There are two black metal rods that I've seen used. I believe one is attached to the A/C compressor. If someone were using an A/C delete pulley would they need to use this bracket? The other one I have no clue what it's for and I'd like to know.
Reverse rotation water pump is needed to run the stock style serpentine, right?
Also, would a power steering pump from say a pre 80's truck bolt up into the aluminum bracket fine? I'm not sure if the older v-belt trucks had the same mounting pattern on the p-pump that the newer serpentine trucks used.
What is the black steel bracket in the bottom right hand portion of the pic used for? Is it needed?
