JACKBURTON55
Registered Member
My truck has a factory tachometer which currently is stuck at 1500 RPM lol. I've never hooked up a tach to an HEI distributor before but i looked at my distributor and it has special connections for the tach and they have wires going to them and appear to be hooked up.
The Tach itself has 3 wires coming from it and only one of those is the same as the what I see on the distributor.
On the distributor there is a ground that goes to the base of the distributor and then 2 others, one that I see connected to the tach and another that goes into a tube of wires and cant trace.
I hope i didnt make this more confusing than it needs to be. I would just like to see the RPMS since I do have a tach. If anyone knows what to look for and do it would be appreciated.
