broncoman6524
I tried to put a factory tach into my truck last night, I wired it up correctly. I know there is power because when you turn the key the needle will got from straight down and "go around" (full sweep) to right back where it started.
If you start the truck the needle just moves faster.
Any suggestions? It's hooked up on the side of the box where it's supposed to be when you eliminate the Stock HEI parts.
Couple days later It worked again until recently it stopped and has been dead since.
