Factory transfer case crossmembers, different heights, what did they come off of?
broflow
Tinbanger
new glarus WI
I'm figuring that someone will know this off the top of their head. Here goes. I want to use the factory style tcase crossmembers to mount my doubler set up. My rig is a 78 K5. I have no idea which crossmember it had in it to begin with. I had a t350/205 to begin with (don't know which crossmember that was). In the pictures I've got 3 different styles, each drops a different amount. I know the one on the left (least amount of drop) is out of a ton truck that I scrapped recently. As for the middle one and the one on the right I don't know. I want to run the style on the right. As you can see I already modified that one. I added some channel to it to bolt it up to tabs I added on the outside of the frame. I want to find another one like that to modify to match so I can have one on the doubler adaptor and 1 on the 203 adaptor. It measures just a little over 5" from top to bottom, the middle one measures 4" from top to bottom. Of course I have 3 of the 4" ones and 2 of the shallow ton style.
Can anyone let me know what year the 5" top to bottom one came out of? I'm guessing it might of been an older blazer? I haven't started junkyard searching yet since I'm not quite sure which year to look for. Or possibly it has more to do with the tranny/transfercase set up 203 vs 205 vs 208? crossmember 2.jpg crossmember 1.jpg crossmember 5.jpg crossmember 4.jpg crossmember 6.jpg
1-tons use the flattest x-member because the frames are taller
84 and older used the flat two left ones. flat one is for 1 tons and middle is for the rest. 85 and newer use the double hump or w looking ones with a couple variants on shape and humps. key is the high center.
I used one tons first style crossmembers for my doubler in my k5. brought the driveline up a little higher.
also 85-up style bolt under frame rail lips for 1/2 and 3/4 ton .
1tons bolt up inside the frame rails .
A guy I know is swapping a TH400 into his '85 K20,which had a SM465...(yeah,I kmow,its a downgrade in most members eyes here,mine included--I would have just put a new clutch in it if it was mine,but he has a GF that cant drive a stick and he's sick of shifting)..
Anyway,his dilema is the T-case in his truck bolted up to the adapter that came with the TH400 (I am pretty sure its an NP-208),but his crossmember is flat like the first two pictured,and the adapter "foot" is too short to reach the mounts..
He asked me what do I need ?--a taller adapter,a different crossmember.or both ?..
Unfortunately I had no answer for him,never having done such a swap since my '72 K5 days 30 years ago..
I suggested maybe he could just make a spacer to take up the difference in height--seems to me someone here had a thread going on this recently ...?..
Ive got my case up as high as I could get it without cutting out the floor. (Case is clocked up and have a 1.5"body lift) I still need the far right crossmember. I don't think that crossmember is out of an 85 or newer though? I cant remember what they look like but I do remember that "double hump" look though.
The right crossmember is unfamiliar to me but looks like first gen dodge or something .
The right crossmember and the middle one are the same except that the right one has 1" more height to it. Don't be confused by the extra channels that I welded on it to allow it to be bolted to the tabs I added to the out side of the frame. (see pict.) I did this because I boxed the frame and am not able to run nuts inside the frame channel.
I don't have it in front of me to measure but I had a crossmember from a 1st gen that looked like the middle one but had deeper bends. Maybe that's what you have.
