reposting this here for more eyes.
according to the inspection report, my ps rear brake is hardly working at all. I assumed it was out of adjustment, but after checking it, everything looks good. I bled the brakes just now to be sure that wasn't the issue and I got no air out of that line.
I replaced that wheel cylinder a few months ago, but it's not leaking. Is it possible that it's not working? Has anyone ever had that problem?
Since the other rear brake is working just fine, the only other thing I can think of is the line being clogged between the 'T' and the wheel cylinder, but that seems unlikely. I just bled the line and there certainly seemed to be plenty of fluid coming out.
I also failed emissions at idle. They said it's running too rich so I'm assuming I need to readjust the carb or something. I suck at this stuff, but I've got an edlebrock 1405, so I'll use some google-fu and see if I can't find any info on it.
Any other suggestions on cleaning up my emissions?
I've attached both reports below.
but after replacement, the rears still didn't work.
