Failed Emissions (NOx) need help *FIXED*
greyhoundjc
Georgia
I just failed the state emissions in my 82 K5 with 350 motor and Holley Truck Avenger Carb/Holley intake manifold. The truck has a catalytic converter that appears to be fine. I bought it last year and all of the material is still intact inside. There is no EGR valve. The air pump has been disconnected by one of the previous owners. This is the last year that I have to fool with emissions on this truck, so any type of quick "band aids" in order to pass would be welcome.
Test Results:
25/25 Test 50/15 Test
Reading Allowed Reading Allowed
HC ppm 54 281 53 286
CO% 0.03 2.26 0.02 1.64
NOxppm 2520 1980 2928 2125
RPM 1451 2500 max 1410 2500 max
CO+CO2 11.9 6.0 min 12.4 6.0 min
Test Results:
I would say it needs the EGR and Airpump back on it.
Ira
It will never pass without the air pump and egr disco......need air to get the cat hot enough to work....
I do know that the EGR is pretty important. I've been able to pass the last two years without the EGR, but then they just did a 2 speed idle test. I've been to four different places and this year their pretty persistant about testing the truck on the dyno.
Heat is the cause of NOx. Check the timing, that will cause NOx too. The cat has to be good and hot before itll light off and work, was it cold when you took it to get tested?
The truck was up to operating temp, but I probably should have run it for longer than I did. Any idea of which way to go with the timing?
Well in CA we can only go +/- 3* form spec. Check the spec, check what it is, it might be too advanced.
Georgia has realitivly easy tests compared to other states. The only thing they visually inspect is to verify the cat is installed. So I can adjust the timing as much as necessary, I'm just not sure which way to go with it. The tag for my truck states 4* advanced. But that was for the 305 that it originally came with. I assume that the 350 is in the same neighborhood. The marks are hard to read, but I'm probably around 4-6* adv.
I passed the test today. I put 3 gallons of methanol in the tank with about 15 gallons of 93 octane gas. Passed with flying colors. It dropped the NOx down to 568 from 2520.
hmm. im having the same problem passing, except the last time i passed nox and failed co
would this work for carbons also?
where do you get methanol?
thanks
It did lower all of my emissions, but the biggest difference by far was in the NOx. I found a place that sold different types of racing fuels and they had methanol. It was a little less than $5 per gallon. The guy at the place said that he sells alot of methanol to people trying to pass emissions.
