79rustyk10
3/4 ton status
The weekend before last christmas, I put a new fan clutch in my DD. I was rushing because I had to leave to get to my parents place and I forgot to tighten the the bolts that hold the clutch to the water pump.
needless to say about an hour down the road theres a second of a bad vibration then bang, I loose power steering and the batery light turns on.
Long story shortened up because it really doesnt matter, The fan got bent up a little bit and I just bent it back to get the thing going again.
I think there is excessive fan noise and its getting pretty anoying, could it be that the fan not being 100% true is causing the noise?
...............................................................................................I had bent a blade slightly on it one day while working on the engine,I was lying over the engine and my foot slipped,and bent one of the blades,and probably cracked it!--to get home,(4 miles up the road),I had to bend the blade opposite the missing one until it broke off,then it ran somewhat smoother again,and I was able to duct tape the upper hose and fill the radiator with some swampy water alongside of the highway...................................................................................................................................................................................................................A bent fan will be impossible to balance,and will exert bad side loads on water pump bearings & fan clutch, and can kill one in a hurry,and the vibrations wont do any good to the engine or tranny either...and it could fail like mine did,and end up slicing someones jugular or worse...the hood on my '56 was at least double the thickness of a later truck,and it sliced right thru it like nothing...looked like an axe came thru it!...
