Fans, rad, fuse box, parallel flow condenser, tranny filter/cooler pics...and blood
nutt7
Ahwatukee, AZ -> JBLM, WA
So I had this "made in taiwan" core support that cracked and jacked my cooler mounts and stuff so I replaced it. It weighed about 2/3 the chevy one I put back in. While I was at it, I put in a champion 4 core radiator, a parallel flow condenser, a junkyard trans cooler, relocated tranny filter, windstar fans, 94 f150 fuse/relay box and a few others.
Broken support:
So I installed a relay box since I was installing windstar fans, doing headlight mod (what a difference!), and adding a bigger distribution block to the firewall. I have had bad luck with fusible links in the past too (namely the bastard by the starter), so I moved that wire in there too. The box has maxi fuse holders, standard fuse spots, and 5 relays in it. I had to modify the wires in the box to accommodate the higher amp circuits I am/will run. I also found these 30a breakers that fit the maxi holders so I can have everything in one nice spot. I ran a short 2 gauge wire from the battery to the fuse box for supply.
Yes, it says Ford on top of it. :rolleyes:
Most of those are spares or ready to be hooked up to something later. I put the max sized fuse in each place so I know what can be run from it in the future. I picked this box because of its versatility and ease of mounting. If you are wondering where my coolant reservoir is, I relocated it and swapped it with a nicer one from the jy:
If you are wondering where the charcoal can is, I mounted it on the core support, by the radiator.
Here is the larger dist. block from a 90 something chevy truck:
The split loomed 8ga wire now supplies it.
My trans filter resides under the battery. It is still quite accessible:
Here is the front. Notice the shorter parallel flow condenser. I have had good results from it so far.
Here is a shot of the rad and fans. Check the ghetto fab rad mounts:
I had brackets welded onto the rad so the fans and rad are one unit...not sure if that will end up being a wise choice...The welder seemed like he was on drugs...long story, but he welded nice beads, just didn't do much for support of vertical forces, hence the little plumbers strap for a lil more insurance...BTW, that is a Dayco 70548 radiator hose. I had to get one to fit the 1.5 inch inlet of the rad. (common issue w/ aftermarket radiators). The stock hose goes from 1.5 at the water neck to 1.25 at the radiator.
I jacked the inlet of my evaporator trying to remove the orifice tube...it was STUCK! I put on a crush sleeve repair kit to patch it and give me a new orifice seat. After I cut the tube, I stuck a #3 phillips in there and had to hammer in on the ground a few times to knock it out. :eek1:
Oh, I promised blood...a little slip of the ratchet...those cooler edges aren't smooth :eek1::
I left out some details, so if you have questions, comments, or concerns let me know! Thanks for looking :D
Looks good! Thanks for the Dayco number, I'll be going down that path eventually with a Champion radiator, finding the right hoses can be a bear. Is that the largest radiator champion made for your application? My Dad had to add some spacers between the rubber mounts and upper bracket, but other than that it fit well. I've got different plans for mounting my radiator, I had been leaning towards how the 1st gen Camaro's did it, but the later "pin mounts" might be pretty nice as well. Like you, I'm not sure how well those radiators will hold up to mounts that aren't very supportive.
At first I didn't understand why the OEM's started using those underhood relay/fuse centers. Now I do. They sure help keep all the wiring clean and compact, and when you start getting into a bunch of relays and added circuits, it just makes sense. There is only so much room on that stock fuse panel under the dash.
me likey the trans filter...I need to do that...:waytogo:
That is the largest radiator. It's the mc716. I found big block rad mounts but like your dad found out, they don't quite reach down enough. The rubber insulators from a 90s truck are at least twice as thick as ours, (see mine) so installing them helps close that gap. Also, all 90s trucks seem to use the same insulators, regardless of rad size. (they fit over the tanks of larger rads)
