Felton PA 17322 Axles\T Cases\Trannies\Wheels
2High4U
Felton Pennsylvania
Wheels
American Racing Teflon Coated 8 Lug Wheels 18" $500
http://exaltmotorsports.com/i-369388...-5-teflon.html
4L60E Transmission W\ B29 Torque Converter 2WD [ Rebuilt Never Used ] $750
TH350 4WD W\ Converter [ 3-5K on it ] $300
Dana 44 [ 8 Lug Complete Hub - Hub ] $500 FOR BOTH DANA 44 AND 14 BOLT AXLES
14 Bolt FF [ 1 Ton Spring Perches Moved to 39" Centers Factory Gov-Loc 4.10 Gears ]
NP 208 Transfer Case Was Bolted To TH350 $100
NP 203 Transfer Case Was Bolted To SM465 $50
What years are the axles?
Are they in running order?
I am not sure what year the axles are, I think the front axle came out of a Cheyene Super. It was a half ton front and i converted from 6 lug to 8 lug. I used it for my 86 gmc half ton then moved it to my blazer. the front axle has SS braided brake lines and a longer steering arm for i believe 4-6 lift. The 14 bolt I just picked up and didn't get a chance to take a good look at it yet. The info I was told was...
14 bolt full floater with 4.10 with spring perches moved to 39" centers for blazer or 1/2 ton trucks. factory gov-loc.
The front should be in running order, not 100% sure about the rear as I didn't check it out yet. Ive been pretty busy lately Ill let you know when I give them a look over. it seems to be complete. Ill also try and take pictures and get the numbers off of them too.
