Few things updated 3/12
lak2004
Durango, CO
Everything is OBO, please feel free to send me any offers.
If you are in great need of something and dont have much cash PM me and we will make it work.
Thanks! Located in Durango, CO 81301
USED fuel pump mechanical, only ran for a couple hundred miles before taken off- FREE+ shipping!!!!!!
Heater control switch w/cables-$5
Interior heater ducting box no A/C or dash vents w/good heater core-$10
87-95 350 engine block, was running when pulled-$50
Block #:14093638
72-73 307/350 75cc cylinder heads, on block above running when pulled-$40
Heads #:3998991
TBI intake manifold, #14102182 1990 G30 van, needs to be cleaned up-$15
TBI Intake manidold, #10108449, needs a good cleaning and EGR put back on-$15
Valve covers off a 350, clean-$10
Coolant recovery tank from 85 K5, cap is cracked- FREE+ shipping
All parts are located in Durango, CO 81301. Thanks
A little more info please, do these replace everything needed? mine leak:crazy:
Sliding Side Window Seal/Rubber-$15x2
Those and the 36-6197 are for the sliding rear windows I believe I tried to find info from lmctruck.com for both but could only find those (36-6196)
http://www.lmctruck.com/ICATALOG/BZC/full.aspx?Page=13
they are #18 on that page, not sure where the 6197s go
I believe that the 36-6197 are the left side on the picture with the 36-6198 it has an "R" meaning the right side. can you please confirm if I am right. If so I will take them.
I guess I am not seeing the same part #s you are. I dont see a 36-6197 or 36-6198 anywhere on lmc. My only guess is they are old part numbers.
edit: Ok just called lmc and the 31-6197 is an old part number and he said its for the sliding rear window on an 80-91 blazer. I believe they just upgraded and consolidated part numbers or something. I think it could have been a 2 piece set or something. He couldnt tell me much, only that it was for 80-91 blazer rear sliding windows. I got them from the PO so I have no idea and I am not by my blazer at the moment to double check where they would go.
What else do you have? I'll probably take the cowl seal and windshield rubber if you still have them.
yep still got those, umm well i have a tbi 350 block that needs new piston rings/possible rebuild and some heads from a 72-73 307/350 that are 76cc. I am sure I have more. I am just ripping my blazer apart and getting rid of all kinds of stuff. I also have inner front fenders that are slightly cut.
hey nightmare, were you the guy i sold the zero rates to here in durango? cant quite remember.
