vortec
My jeeper buddy says that he's seen kits to make a D44 into a FF. Do they have anything like that for a 14blt SF?
. but the bright side of the SF is less weight and better clearance.The only reason it makes sense is that I could have one for free. I don't have a free FF. but the bright side of the SF is less weight and better clearance.
How is it free? Do you not have to BUY the kit?
Looked into it for the shear fact of weight reduction and better clearance. It damn sure aint free though!!!! Wowsers!
so you're saying there IS a kit? you found one?
no, not a free kit. free 14Blt sf
so could i be confident in my 10b rear with after market shafts in it? im only fond of mud really and the axle is already geared and posi, id like to keep it. i was thinking of buying a 14sf just for the tire size capabilities but that leaves my front. anyways...
What's your intention? 14SF is beefy, the fact that it's an SF has little bearing on how well it will work in a given applicaiton.
I would want a 14bff over a sf just because A) it's FF, which to me means 2 wheel bearings per side instead of one B) no wheels falling off from broken shafts and C) any aftermarket traction aid is more $$ for a SF than FF.
I don't wheel hard enough that i am consistently concerned about breaking an axle, but since i'm running a 10-bolt, it's a real possibility. I was looking at this as a potential oportunity to get the best of both worlds. more strength, and FF peace of mind without sacrificing too much clearance or adding too much weight. I'm still really leaning towards taking the SF, anyway. definitely better than my 10 bolt. If i don't take it, it's staying on the truck and going to my little cousin when she turns 16, in a few months. a tiny little chick in a 3/4 ton chevy would give me a laugh, though.
) Search the posts, the 14SF is a HECK of a lot stronger than the 10 bolt, and is not even close to being on the same level of strength, even though both are SF.You break a 14SF axleshaft, props to you.
Seriously, get the axle, its free, use it, if it breaks, you are out nothing. (of course I'm guessing it's the wrong ratio?) Search the posts, the 14SF is a HECK of a lot stronger than the 10 bolt, and is not even close to being on the same level of strength, even though both are SF.
I don't believe I've heard of a single 14SF axleshaft failure.
Even if there are half as many people using the 14SF as 14FF's, I've still heard of one or two 14FF axleshaft failures, and a couple of hub bearing issues IIRC. With the strength increase over even a 14SF, you'd expect to hear of at least a couple 14SF failures.
