FGB52! (first generation b52!)
cybrfire
1 ton status
Iowa
FGB52 (FIRST GEN B52)
Another one for you first gen guys!
I must admit, the more I work on this truck the more I'm starting to become a first gen guy myself!
This is pretty much a bolt on deal. It is offered in two forms, Front hangers only and Front and rear of the spring together.
First off the front is much like our other B52 kit. The bracket itself bolts on in one place only. The rear most adjustment hole will get your 52's mounted, keep your tire centered in the wheel well and will require moving the frame eye hanger. Moving the spring all the way to the front will of course set your axle forward. It will also be possible at this location to use your existing frame eye hanger. In between holes, well you get the idea. More options are a good thing!
If you decide to keep your axle in its current location as shown below, We have the frame eye hanger kit for you. This is specific to the first gen. Uses existing holes as much as possible for easy installation. Here's the catch! If your running an automatic transmission, You will need to fab up a support rod for the shift linkage or go to a cable shift set up.
On to the photographs and please ask any questions you may have. It'll help me figure out what points I need to hit on when I post this on the website!
FGB52 hangers and all the backer plates.
FGB52 hanger mounted up spring in the rear most position to keep the axle in the stock location.
Inside the frame rail, A shot of the backer plates. Not shown in the photo, we have included another bolt location further forward on the frame to add some additional support.
Here's a shot of the frame eye hanger kit. It will include the frame eye hangers, fill plates for the hole left over, hardware and bushings, 9/16" bolts and the shackles themselves. The shackles are a bit different. For bolt head clearance we spaced the outboard shackle away from the frame .25". We don't want that shackle and those bolt heads arguing! This is a 6" shackle and the front end of the truck is bare frame with the engine and trans. No sheetmetal or cab so the angle is about perfect with some more weight on there.
inside the rail on the pass side. Hole not filled yet with the included fill plates.
very nice. I don't even own a first gen and I'm digging it. :thumb:
btw, whatdya have for front spring hangers for guys with no body left (ie don't need the body mount part of the bracketry)??? anything cool? :)
j
Take a look at Mikeydo5's rig. He's got some photos of the B52 without body mounts!
would it be feasable to make the bracketry 2" taller to assist in pinion angle? How did his pinion angle turn out?
when I placed my 52's in the front of my burb I used the 6" shackle and the stock upper frame shackle mount. in doing so it has the axle sitting back about 1". and my pinion points straight back.
I'd like to gain 2" in the bracket to help out and keep the wheels centered in the wheel well. could it be done???
The pinion is pointed straight back. Could use a tapered shim. 4* It's kinda hard to say at this point though. The rear has not yet been lifted and the front is super light so the rear of the spring is gona come up some yet.
Your looking for 2" of height in the front? I'd be concerned with stress on the frame horn. A crossmember would be required at the very least.
He's already sent me the pics... very nice. Hopefully you remember how to make them. :thumb: :grin: It'll be awhile before I mess with the front end again though...
j
j
No problem there! Whenever your ready give me a shout!
Thanks guys, we do our best! All the comps are much appreciated!
This setup looks awesome, hope to get one from you in the near future.
Look nice :D .That didn't take long after I asked you about needing a frame for a jig :D . Too bad I'm tearing my 67' apart :o .I guess I'll have to build another 1st gen rig.
since there's no directions on where to place the eye hangers...how far back do i move it from the stock location to keep the wheels centered in the wheel well with 52" springs and keep a good shackle angle on my 67 gmc
In this photo, it looks like the bracket uses existing holes to align it. :dunno:
i could have assumed, i just wanted to verify before putting another 2" hole in my frame
