Fiberglass dash pad?
scoots90245
1/16 ton status
El Segundo
Has anyone used one of these from ebay?​
i would rather not throw $400 at something none of our members have tried. TIA
81-87 Chevy Truck Fiberglass Dashboard Replacement Dash Pad c10​
Truckz n Stuff
Truckz n Stuff
I haven't used it but I like the fact our dash has a steel layer to strengthen it.
Fiberglass is reinforced but could still break.
With how we treat our trucks off road I wouldn't use Fiberglass.
But if you are just cruising it, it should be fine.
However if you look at the pictures, I think you will need to put in some work in the surface because the finishing leaves something to be desired. Wavy surface and some wrinkles too
The urethane one I got from jegs took a lot of trimming on the outside then once installed on the dash the speedo bezel wouldn’t fit needs more cutting but then it’ll look hacked
