So, I'm installing a camper shell window in the fiberglass top on my K5. I've done it a couple of times before, but never ran into this issue. This window is shorter than the others, and I didn't realize how concave the top is right above the window. I'm left with about a .25" gap between the aluminum window frame and the fiberglass top. The frame extends about a half inch into the top, but doesn't go past the inside lip of the fiberglass window channel. Meaning any water will go right down the inside of the back window and soak everything inside.
I can only think of two options...if anyone has any other ideas, please let me know. I can fill the whole gap with clear silicone, or I can try to fill the gap with bondo or fiberglass repair or epoxy or some similar material and hope that there isn't enough flex to crack it and allow the water through. I am reluctant to try to shave away any more of the corners since I'm seeing fibers already and I don't want the top to be so thin it won't support the weight of the glass. And I will never be able to get enough off to make it lay flat.
Suggestions? If I go the filler route, what would be best to use? Fiberglass repair, bondo? I will be painting the top when it's done, so appearance is not an issue, plus it'll only be visible from the roof of the truck, so it doesn't have to be pretty.
