When I test drove the Jimmy, I noticed that my top had a shimmy at the rear with the window down. After further investigation I noticed that the rivet in the weather strip channel has the head broke off, and the overlap area on the outside of the rear corners have small cracks. Would that rivet really be the only thing reinforcing the top?
Also the tail gate opening has spread enough that the gate does not latch on the passenger side. I tried to check the bedsides with a framing square but they didn't look too out of wack?
Need some advice...Thx
