File this under WTF is this???
TommyD11730
NY
84 K20. 350 with 700R4. This switch is mounted to the firewall near the brake booster. Has both vacuum and electric running to it. Anyone have a clue what it is?
Might be they put it there anyway,in case it came with a TH350C transmission--or perhaps they use it for another purpose other than controlling the torque converter lock up...?...
Yep. That's how GM handled converter lockup without a computer. I'm guessing that is what was used to determine the load on the engine in order to electronically engage/disengage the converter. From my '83, I felt it was a pretty good system. Mine never gave me any problems.
Thanks Guys. I followed the vacuum diagram and it sounds like basically your correct. Works off ported vacuum so I guess it's a poor man's TPS :)
My '81 G-10 van with a TH350C transmission has that same vacuum switch...never had issues with it,though when I first got the van I discovered the converter wasn't locking up ,due to the stoplight switch being out of adjustment...one night I noticed the brake lights were "stuck on"..
I had noticed the transmission seemed to be running "hot" on a long trip (150 miles) I made,and when I listened for the RPMs to drop when I stepped on the brakes and it didn't,I realized the stoplight switch is tied into the lockup circut--once I adjusted the pedal switch the converted locked up normally again...probably would have cooked it eventually if I had not discovered that !..
I have seen similar setups on other cars used to shut off the A/C compressor on wide open throttle too..gives you a few HP back when its most needed..
