Yeah I was reading up on combustion temps, and apparently they exceed aluminums melting point every time the cylinder fires, but the amount of time that heat is in the cylinder isn't long enough to cause damage, again under normal operating conditions. Melted pistons are obviously possible though!
With a plug between two exhaust valves, you'd be seeing double the heat output, which would heat that area up more. With combustion temps exceeding aluminums melting point on every firing (assuming the melting point of pistons is somewhere around 1200* and combustion is somewhere around 1500*) the only reason pistons don't melt is because they don't have time to absorb the heat. Double the amount of time the heat produced on every combustion event stays in the cylinder and the result would be a melted piston in short order. I mean, you can melt aluminum over a wood fire.
In any case, I'm just having fun analyzing the possiblities. If you've seen them built and run them this way, I'm sure there is no issue, and there is no reason to argue with success. Besides, even if they started to melt or break apart, I'd expect they'd go downstream which wouldn't be catastrophic.
It all sounds good.
