filter for assist
sope
British Columbia
Does anybody run a filter for their hydro assist? Mines going in right now and it seems like a good idea. Any thoughts?
Boz42 ran one on his for a day or two. It was too restrictive so he ditched it. He was running a Redneck Ram set up with .75" rod. Worked much better after he took it off. Something to keep in mind- be sure to keep the reservoir cap the highest part of the system, otherwise when you turn it off the fluid will back up and spew out the cap.
Well I found a GM part # for a 93 Seville PS filter. It's PF 2150. This is an in line filter. I'm going to check it out today. I might end up with a spin on and housing.
Anybody have any idea what GPM's a PS pump puts out? I have the higher flow PSC one.
PSC should be able to tell you.
Boz had the spin on kind like from farm or heavy equipment.
