FINALLY! Got me anew rear (14 bff) Coming!
BrianDamage
Alabama
Been riding on prayers the past year and a 1/2 to 2 years that my axle wasn't going to give up on me. I don't drive the K5 except to hunt out of anymore, but due to the yoke on the stock rear being extremely loose, I was going through u-joints like crazy.
I bit the bullet and bought this one on ebay today
http://cgi.ebay.com/ebaymotors/NEW-14-bolt-rear-4-56-detroit-disc-brakes-dana-60_W0QQitemZ8058648126QQcategoryZ33731QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
all my overtime is paying off I guess :D
I plan to swap rears, and just unhook the front shaft until I can get a 60 for up front since the gears are differant. ( hopefully have it by hunting season)...going to just get some el cheapo 8 lug rims and keep the same 33" tires until then.
Anything I need to know about the swap? been reading the articles on tech, but I've never done it before.
Wheres a good place on lineto get some new u-bolts that will fit this axle?
What about brakes? Do I need to buy a proportioning valve or something to get these to work? Line lock or other for an e-brake?
Is that enuff questions?? :D
Hell, I'm excited...I'll finally be able to drive the K5 without worrying about the rear end grenading on me. :D
seams kind of of pricey. especially if your going to re gear it. I spent a total of $550 on my 14ff but it had 4.10s which I needed. It's locked, shaved and disk'd that I did on my own. I'm going to be re gearing it soon. so It should be under $900 total. not trying to bring you down. but you waited long enough that you could have been building it during that couple of years that you been praying that your axle doesn’t blow up on you.
anyways you'll need a conversion ujoint and ubolts and you may have to move the spring perches and shock mounts. I have a feeling that the axle was a surplus 14ff for a cucv that all they did was a disk brake conversion to....
You realize the rear he got was brand spanking new?
yeah, I do realize that! I'm just saying thats alot of cash for a axle that he's going to re gear and something he could have been building through out that 2 year period. but then again it's his cash :D
It sounds to me like he's regearing the front when he finds a D60. Disc brake kit is 300-500 depending on who you get it from. Therefore at the most he only paid 675 for a brand new detroit, dana gears and new housing with axles and hubs.
I understand he might have gotten a better deal on a good used one, but he know the condition of this one without ever even replacing a seal.
You will have to move the spring pads and shock mounts,pretty good idea that those were military surplus.
Congrats, I was looking at that auction but shipping to the west coast would cost too much.Let me/us know how the install goes.
smokkey1 said:
seams kind of of pricey. especially if your going to re gear it. [\quote]
not going to regear it...gearing just does not match the stock front axle that is in it already
yeah, after re reading I realized that the front was going to be mismatched. and that you were not going to regear the 14ff. so then yeah good deal. make sure it comes with the ubolt plates. and your going to need brake lines too.
Sweet axle....but it was hella expensive. I got the same setup, brand new for $550. But, its good to see someone doing some upgrades.:D
-Harrison
I would not drop the front drive shaft, even though your gearing is different then front and back you may find yourself needing it, it can be used for emergency situations. I have 5.13's in the back and 3.73's in the front, currently building my d60, which of course will be 5.13's. I had to use 4x4 both Sat. and Sun., but this is only in mud. I have personally know one person who bought a truck new and it was geared wrong from the factory and he used it all the time! Took the dealer a long time to figure out the problem. For my 2 cents I think you got a decent deal, I put a hair over $2500 into my 14bff, what a money sucking addiction this is.
Running mismatched gears will destroy your ring and pinion. It may work for a while in slick mud where there is zero traction, but when I was 4.56 in the rear and 3.42 in the front with the 4wd engaged on the grass, it was pushing the front tires along. Drove like crap, made a horrible noise, and probably wouldnt have made it much farther than the 50 feet i drove it.:crazy:
-Harrison
broc944 said:
I did say emergency situations.
Yeah...i got ya. If i were him though, i just wouldnt get myself into a situation that needed 4x4 until i re-geared. Better safe than sorry. But if you must, it can be done in emergency situations....its just iffy
-Harrison
Buddy of mine had an 84 shortbed, 2.73 front 3.08 rear. He decided to take a short cut through a little mud pit and got stuck. Put it in 4wd and broke his front ujoint straps, it was pretty sticky mud not real slimy. So i'd stay away from the mud.
Just stay out of 4wd thats all. Dont go wheeling if your gears arent matched. Slimy mud may be the only thing thats ok....but to run mismatched gears on high traction surfaces such as rock.....:shame: :shame: :shame:
-Harrison
