finally we have ignition
rbk587
Registered Member
brandon ms
ok guys first thanks for all your help.....i finally got module installed and she cranked.took her test driving and she ran fair but got worse as i drove it was like no power or sluggish.is this a timing issue maybe and can you tell me how to time and at what as i have a timing light but has been long time thanks for any input:confused:
There is a single wire weather pack connector by the steering column in the engine bay.
DIsconnect this wire, connect your timing light to the #1 plug wire (front drivers side), and read timing. I'd set it at about 4˚.
Then reconnect the advance wire.
