Fire extinguisher question
AJMBLAZER
Better to be lucky than good.
Staff member
Moderator
Paducah, KY
Place I work for is replacing some of it's older but still certifiable fire extinguishers. They're offering them to us. 5lb and 10lb extinguishers, a few ABC and most are dry powder. Any advantages to either? I think I could fit the 5lb in the truck but free is free, I can always stick it in the bed if it's too big or keep it for the house.
ABC and dry chem are pretty much the same. They put out any type of convention fire (normal conbustables, flamable liquids such as oil/grease and electrical) If they are still filled and not leaking powder i would grab them, always good to have around. Youll see most dry chems are bc or abc but a bc will put out normal conbustables too, just messy/a waste if you have a water can. For a fire under the hood a nice big dry chem could be quite effective, for electrical it could be equally effective, but i would prefer to have CO2 and dry chem. As far as size goes, the bigger the better but with the right skills youd be surprised what can be done with a small extingisher.
Oooookay...so our maintenance guys used to be used car salesmen...I now am the proud owner of an old fire extinguisher that needs a charge and basically is probably trash.
How do you properly dispose of one of these?
Just for practice make a controlled fire and put the fire out. No joke, if your gunna throw them out anyway and you or somebody else has never done it, it is good practice!
as long as they have no pressure toss em in the trash, I recycle the poweder for recharges, but no need in your case.
I give away old fx all the time, the info posted above by dabba is good info, the larger the better but a 5 lb is great fx fr a truck, a clean guard/halon. hallontro would be better and cleaner but the are spendy. a 5lb abc is nice to have and should get the gob done.
as for needing one, find out by looking on the tags of some at work and when the guy comes out ask him for some old ones, he should be more than happy to give you some! if you choose to buy new just stay aay from a fx with a plastic head..but in the end something is better than nothing..well that is untill it looses pressure and you find that out at the worst point in time..:doah:
best advice is to try to conserve it, dont just spray. When you use dry chem, dont inhale the powder, its not fun. I dont know why he gave you one that needs charging, its useless and you might as well buy new. i also suggest trying to find co2 extinguishers as a backup and for electrical type fires. They work great for those as long as you cut the power first. That powder gets everywhere and is a bitch to clean up. I hvant really seen co2 extinguishers for sale commerically but i havnt really looked, im going to try and see. Might pick up a 10 pounder too. Ive seen some pictures of burnt out blazers and i dont want mine to be one, she backfires a decent ammount too because the holly she has is way too big.
Edit: also i forgot to add. If you have old ones or whatever. it is good to set up a fire and practice just as scotto said. fire extinguishers become far more effective in the hands of someone who knows what their doing. Dry chem is pretty easy to use, the powder just gets everywhere and smothers the fire. Water cans are harder than people think to use effectivley and co2 extinguishers are also a little more difficult to use effectivly. Most people dont get close enough for it to work. CO2 you need to be pretty close. As part of my training i had the pleasure of using a co2 extinguisher agiast a stack of burning pallets. Most people didnt get close enough to even affect the fire, i got close enough to starting putting it out but had a nice sunburn after. That was a poor application for CO2, plus it was a windy day. Anyhoo its a good idea to practice and try to carry both.
i dont think water cans are worth carrying because most likley whats burning is a b or c fire.
