Brian, that is the nices fan setup I have seen. Can you give the specs of the fans as far as the CFM and diameter of each and which fans you got. Also, how did you make the shroud? Is it aluminum or sheet metal and did you weld the corners of the shroud or use rivets? All the info would be very helful. Great job and nice looking engine too.
