First gen parts for sale soft top D44 and more
earl87gta
Chuckey TN
I have a best top soft top for sale it has been on the truck for a year and has one spot on the rear window ware the seam is starting to come a part nuthing that cant be fixed and you will never now ut had a problem.
I have 1 d44 with 3:73 gears flat top knuckes $100 and one d44 and 12bolt matching set need some work $150 for both I will have to check the gears for these.
A set of aluminam inserts for the dash and glove box that were made to use with after market gages but will work with stock if you dont mind a perfict fit on the gages the holes are just a little smaller $50 for both.
One non tilt steering column with grant wheel $25.
2 stock roll bars $75 each.
4 MT clasic II 16.5 x 9.75 Wheels $250.
4 MT Baja Belted 36x14.50 tires 300.
1 tube grill and outer grill for 72 chevy $100.
1 steering stablizer $15.
1 sway bar $15
Make me an offer Im trying to get the money together to buy the rest of my drive line to get the blazer back on the road.
Bith d44 are out of 72 blazers and thier both 6 lub the sway bar is just the bar but I will thrw in the cross brace and spring plates for $25 more Iwill have to take the brace off the blazer I just left it on and I will need to get the plate off my truck but I do have every thing. thier are pics of the grill here http://67-72chevytrucks.com/vboard/showthread.php3?s=&threadid=80985
It has one dent in the outer grill and the grill is sterting to rust I was going to paint it black but whent with a 68 front end instead. Ill try to get a close up pic tomarrow.
So whats the deal on the roll bar? pics?
Make me a deal /forums/images/graemlins/deal.gif
Sealy, Texas 77474
Greyhound ships cheap /forums/images/graemlins/grin.gif
Im going to try and get pics of the roll bars may be tomarrow I am going to try and borrow a better camra.
[ QUOTE ]
[/ QUOTE ]
Thanks cause I still want one /forums/images/graemlins/thumb.gif
Sorry guys Ive been working the night shifft and for some reason my PC at work will not let me log on. I tried to get pics posted but I have to post them at 67-72chevytrucks.com and they have somthing not working over thier right now. I had some pics that I took with my ohine but thier site is down to so I can post pics that way now ether Im trying to borro a camrra to get a good pic. I still have a d44 left but Im not sure on the gears it should bolt right it for oyu if you have a 10 bolt you will have to change the break lines.
