I'm looking for a set of first gen pullies to use with or without A/C. I need the one that mounts to the water pump and the one that bolts up to the harmonic balancer.
you know i just scrapped several crates full of 72 and 68 older pullies and bracketries and such, humm..
ill see if i got anything at all that i missed when i scrapped out though,.
you needing the flat or dished crank pulley and what diameter and depth for water pump and what bolt pattern on the pump one, small or large ? large was mainly long pump pattern and small was mainly small pump pattern but not all years.
