RGV72BLAZER said:hey Kert, had some trouble getting the darn thing into my Gen1. let me rephrase, it was a PITA. lol. my buddy broke one of the bolts in the block when he was tightening it, so we're going to put some tack welds in it, you see any problem with this or should i pull the motor out again and fix the broking bolt? also there's very little clearance under the oil pan and on one part is even making contact, may be a crooked pan but doubt it. any thoughts?? thanks.
Are you talking about tack welding the bolt in? Is it tight? or not able to tighten?
Can you shoot a photo of where you have pan contact? Nobody else has reported any problems as of yet.
Dozen or so of these out there all coming off the same fixture so we'll see. Actually you got the proto crossmember that was assembled on the rig and the first one off the fixture went back in the rig to qualify the fixture.
