First Post, Intro and an Issue
brassnut
Registered Member
Shady Shores, Tx
Hello, this is my first post so I'll start by saying how very informative and encouraging this site is to me.
Some background:
I have an 81 blazer with 350/350/208. It has a 10 bolt front 3.73 and a 12 bolt rear 3.08 ( I'm working on 3.73 for the rear). It currently has no front driveshaft installed(too short after lift). It has a 4" RC spring front blocks rear lift with 35/12.5/15 general grabbers on blk crawler wheels. It has a Ord weld in frame brace/repair kit up front. The TH350 was rebuilt about 6 months ago by a questionable shop( the price was right at the time). I just had the front aligned and tires balanced about a week ago. I just a new driveshaft made last weekend with new ujoints, balanced and made to be 33" long to fit after the lift made the old one too short to use.
Issue:
I had some driveline vibrations at all speeds before I got the new DS installed last weekend. Now I only have vibrations when I am going between 0-10 mph. Does not matter if I am acceling or deceling or braking, just getting the vibes in that range. I notice that on decel, if I throw it in neutral, I have no Vibes at all. I am thinking that maybe the Torque converter could be suspect, but am not sure. I can drive at all freeway cruising speeds and it's very smooth. Any help would be great! Thanks
Austin
welcome!!
I say pinion angle is too low. That's my guess. Do you have an angle finder? Some numbers would help solve this.
I will get some mesurements when I get home. Also, I noticed that the T-Case has already been dropped by PO. Should I put it back to stock without the spacers between the frame and the cross member? Why would anyone drop the tcase without a lift? I also know that the blocks in the rear for the lift had the tapered ends forward so to tilt the pinion up a little.
I tried to attatch pics of the angles. Only thing that has changed since pics is the driveshaft is 2" longer with new ujoints
