I would listen to him...What do you plan to put on it? How much weight? What is the floor going to be? Rectangular would be better no matter what you are doing.
going to be a DD rig more than a wheeler, so that added space (even if not all that much) will be better, and will help hide the mudflaps a little betterJust a thought, I would taper the rear of the bed. Where the bottom/back right and left corners are on the diagram, I would cut those corner squares into triangles. Shouldn't do really take away much storage capacity, it may look nicer and give less chance of banging and hanging up on rocks and trees, etc. Someone should start a thread on "pics of flatbeds" if there isn't already one.
atv, snowblower, maybe an axle or other parts once in a while.....What do you plan to put on it? How much weight? What is the floor going to be? Rectangular would be better no matter what you are doing.
1x1 is square. 1x2 for floor support only. 2x3 should also be used over the frame rails with another 1x2 on the center of the bed front to back. A little bit over kill now means no rebuild later.
