I made pretty much this identical post in my build thread (http://coloradok5.com/forums/showthread.php?p=3496913#post3496913), but figured there might be more traffic/brains out here. Plus it can't hurt to have a thread just for this.
So I have decided on doing a 3 link w/pannhard for the front end. I have never designed a link suspension, so I have no idea where the numbers should land. Been reading for quite awhile about the design and theory behind it.
This is my fist attempt at coming up with something. First time using any of the link calculators. Now, it's 16* outside and I haven't been too motivated to go out and get any real exact measurements yet, so these are sure to change some. The only real measurements I've taken have been from my K5. I just want to see if I'm heading in the correct direction or setting myself up for failure.
At this point, I'm thinking I'd like my lowers to attach to a new transmission crossmember. Good or bad idea? Or I could do them right off of the frame, most likely under it. Who has done what and how did it work? What would you have changed?
Some things to keep in mind. Truck will be a daily driver, mild trails, sand dunes. Shooting for 3-4" of lift over stock 4wd height (clear 35's with very little trimming).
First crack at it, after figuring out what each value does. I want to say my links will end up shorter, (around 39" maybe?) was just using an eyeball measurement.
Critique my numbers and don't hold back on any advice...I can use all I can get. Sometime this weekend I'm going to make an effort to get the truck in the garage and up in the air at my ideal ride height, will pull some real numbers and decide on a final wheelbase.
This one I raised the link mounts a little.
