apache
Curoius what was the first year of the computer controlled carbs on K5`s,Calif particulary if there was a 49 state and then Ca version.
No, if it still runs, it is not a PCM or an ECM, it is probably just the EST controller. EST doesn't make the spark, it just has the ability to introduce some extra retard from what the dizzy would otherwise be doing.My 84 has a pcm.
Isn't hooked up though.
I believe it controlled the choke and some other ****.
I think the carb 76zimmer had only had a dual volume accelerator pump, not full CCC controls. Havent had to get into one, but I think that this solenoid could either be bypassed or hotwired and it would be just like a regular carb, correct?
