Kain
3/4 ton status
well i asked tech at fiTech will i have to load software and this was Joe reply
The failure was not necessarily caused by heat but was present when the temp of the ECU was increased. So it might have worked cold but when it got hot it failed. It does not hurt to run a spacer if hood clearance allows and anytime you can keep the fuel and electronics cooler the better. The new ecu will be loaded with the correct software but you will have to reset your default numbers, engine cubic inch etc and any tuning that you did.
Thanks,
Joe
Thanks,
Joe
