Fix Transfer Case ???
big jimmy 91
Northwestern Ontario Canada
Long story short....
The rear dr. shaft slip joint u-joint let go and it seems that when this happened it it had enough force to put a hair line crack in the 208 t,c,
The crack is on the rear side of the t.c. housing on the drivers side , on the flat in the middle of no where
So , is there a way to repair it or is a new case in order
The crack is about 5" long and very fine , just enough to notice it seeping and get the dirt wet
Any advice from those that have had this problem.
Thanks
if i were you id just look for another 208 on the cheap to cannibalize the output
case
if he doesn,t take it. i sure will. just let me know. my case is cracked right at the front output yoke. let me know what shipping is to 80461 leadvile co
Sorry , I've been really busy.
You might as well give it to someone else , I think the shipping would cost a lot to the great white north :laugh:
Thanks very much for the offer though :thumb:
