Service mode doesn't exist for these trucks. I believe it is specific to vehicles without keys, aka push button start vehicles.How do I put it into SERVICE MODE?
Also, Cylinder Deactivation Exhaust Control Valve Learn sounds almost as bad...???
The Cylinder Deactivation Control Valve Learn doesn't apply to this either from what I can tell. Not as confident in which vehicles it does apply to, but I don't believe it is this one. The cylinder deactivation technology in these engines is "dumb" in that there isn't a feedback mechanism that knows if the exhaust lifters are collapsed. The solenoids just redirect oil pressure to collapse the lifter. There is no sensor to dictate anything, which means there isn't a "learn" associated with the cylinder deactivation on these engines. Or at least that's what makes sense to me. I attempted to search through the service manual to find anything indicating this learn procedure applied and didn't see anything to that effect.
This procedure is the same across a bunch of vehicles from what I can tell. The service manuals are "live" docs of a sort these days and I think they got too smart. This doesn't appear to apply to these trucks at all from what I can tell. So my thoughts are you can just plug in the new module and be good to go. I did look up an old SMA video and he replaced one of these in a similar year range colorado/canyon and it didn't appear he did any sort of programming.
Good luck!
