fixed 208, 1310 enough?
muddybuddy
1 ton status
Northern, VA
hey guys, im going to be converting my np208 to fixed yoke with the help of K10Andy. i believe the yoke on the dodge fixed is 1310 but im not sure. its the same size as the stock u-joint off the front 10bolt. anyway, i was wondering if this will hold up or if i should upgrade to a 1350. the engine is stock at the moment, but exhaust mods are in the near future. also im going to be swapping in a 14ff and running 513s maybe with a locker. this is my dd, and i only do moderate mudding on weekends.
what do you think?
thanks for the info.
im not looking for stuff for the slip yoke. im using the back half of a Dodge 208 fixed yoke. i would like to know if the stock size is adaquit for the 14ff with 513s and 35s.
alright after looking at the link, 3R is the equivalent to 1330? so then teh dodge must be 1330. is it worth going to 1350, or is it not really worth teh money?
I think you should use a stock front output flange off a 208. Would be much easier to get CV's and what not for it. Plus I think it would be stronger.
