Not sure if this should be in the injection section or not, but I need help and I know all the smart guys hang out in the garage.
My #8 cylinder is dead. I installed new headers and spark plugs, fired it up, and it idled a little rough with some sporadic popping. I have true duals so it was easy to narrow down the problem to the right side. Pulled out the temp gun and all cylinders were warming up to about 170deg, but #8 was about 80deg. I pulled #8 plug and it still looked new and smelled like gas. Swapped it with another cylinder and tried again - #8 was still dead, so not the plug. Checked the wires and distributor and found no signs of trouble.
Truck ran fine before. My next step is a compression check, but I doubt that it's an issue. Truck has a crate motor with about 30K miles on it and has been babied maintenance-wise. Also, it ran fine before and this is a sudden issue unlike a gradual loss of compression.
Could a leaky injector be causing this? Something else? What am I missing?
