When you have the engine running at an idle(running a bit faster than you think it should), spray the carb cleaner around the base of the throttle body. If that turns out to be the problem, it will actually slow the idle speed down as it temporarily cuts off the supply of extra air. This, causing a slower RPM.I picked up a can of carb cleaner about 30 minutes ago. I'm going to give that a shot tomorrow.
This shouldn’t really be that hard to find, as it’s raising the idle speed so high.
I’ve also seen the the rod that is connected to the butterfly plates in the bore of the throttle body, the horizontal bore where the rod sits will actually develop a vacuum leak.
The repair for that was to get some pieces of teflon from an old Holley double-pumper rebuild kit's. Take the rod and butterfly plates apart, force a bit of that teflon bore repair into the bore for the rod, then, reinstall the butterfly plates and rod. The rod will force the teflon to “seal” the bore. Back in the day, this find and repair was considered black magic. No one knew about, let alone how to repair it.
Find that leak the same way as the base leak. Spray carb cleaner, listen for the RPM drop.
And, Bob’s your uncle
