I had a problem with my hydro-boosted steering pump not liking slow speed tight turning with my 38" tires. When I took a good close look at the problem I first found out that I did not have the larger 5/32 steering pressure valve that my V3500 truck is supposed to have. Luckily I had another old steering pump laying around that had the larger 5/32 pressure valve in it. The next problem was not having both steering pump belts on my dual belt pulley. I bought a new A/C compressor for my truck, and now it has both belts on it.
I added on a couple of other things that helped the steering like a smaller diameter steering pump pulley I had laying around that will spin the steering pump faster at lower RPM's. I also installed a steering fluid cooler on my Crew Cab.
Left to right: Trans Cooler, Oil Cooler, Steering Cooler
